anyone using pyplex (or other chromecast-like-but-not-a-chromecast setup)?
I have been wondering about using an rpi in a "chromecast-like" setup by using the web or ios apps to "cast" to an rpi.
In such a case the rpi would not need to run a full PHT instance, as it is just "catching" the stream. This would obviate the need for any rpi-side navigation/UI, no need for a remote (aside from tv remote), and would make it very easy for friends and family to use -- the web client is especially nice for navigating larger libraries.
I have tried the chromecast, but it has some major downsides:
1. most of my media ends up transcoded on chromecast
2. chromecast video performance seemed rather poor (jittery, jumpy, buffering)
3. subtitles didn't work well
4. chromecast has to be "online"
I ran across pyplex a while back, but haven't given it a try yet.
Is anyone actively using it?
Anything similar out there?
Rasplex is still being heavily updated and can do the chomecast-like setup, but also runs full P/HT
I've been very happy with 9.9.16 build
http://rasplex.com/
http://min.us/i/4EUpVgjt7EpW - Image
dale (pyplex founder) runs the rasplex project also... BTW
yup. That was the reason I asked about it in this forum. ;)
http://rasplex.com/
Indeed. rasplex is a great project, and I love the improvement so far.
I was just looking to see if a simpler option was viable, with the thinking that it would have much less overhead to not also run full P/HT.
I haven't touched pyplex about a year, rasplex has been my primary focus.
It isn't too difficult to get pyplex working though, if I had more time i'd build a dedicated pyplex server distro. The code is still available on my github.
Basically you have to have omxplayer installed (I have no idea what has changed in this project in over a year, probably lots), look around for some binaries for raspbian to save time.
Then just install python, clone my repo, and do a bit of hacking. Probably a couple nights worth of work.
As mentioned though, the rasplex is literally a superset of pyplex functionality and is actually actively maintained. Is there a reason why you don't want to just use rasplex?
... Is there a reason why you don't want to just use rasplex?
I actually also use rasplex too!
I am just looking for simpler (alternative) interfaces in general. I liked the idea of the chromecast, but the I found some of the caveats of the current incarnation to be unappealing or lacking (mentioned in first post). If I get some time I will will fiddle around with pyplex.
It is too bad that P/HT itself doesn't have a "startup mode" where it displays a static or rotating screen, and only behaves as a "Cast Receiver".
Aside:  I fully understand your desire to dedicate your finite amount of time to the current feature set of the rasplex. Thanks for all your hard work!
I would recommend the suggestion of the static/rotating screen to be given to the general PHT system.  There is no reason that all of the HT could have some sort of screensaver that could be just running in the background if the user wanted to have it instead of only dim or black screen.  That being said I think they are working with what XBMC gives as a default.
That being said, I have a keyboard hooked up to my pi out of habit but most of the time, I just "cast" to it from my android remote and the picture quality is better then the chromecast.
I'd be interested in something similar as well. My issue is that my old 256mb pi can't handle my library of 800+ movies and 150+ TV Series, it just lags immensely and then freezes when I try and play media. I could however very easily use my android phone to select media and feed it to my pi.
Ask and ye shall receive
This request got me feeling nostalgic enough that I am going to revive pyplex and include it in the main rasplex distro, it's pretty small so why not?
https://github.com/RasPlex/RasPlex/issues/105
It'll probably be a couple weeks before I find the day or so I'd need to implement it (hopefully less!)
See my post ^
That is great news! Thanks for the update Dale.
Just installed fresh raspbian and pyplex from git. I've done all as described in readme file, but pyplex don't work. Need to do somthing else?
