Hi.
I noticed that I cannot access Plex installed on my NAS from my Android app, neither does it play back anything when connecting from Brave browser. The certificate from Letsencrypt is somewhat strange (has a strange/non-existing domain like “plex.direct”) - did something change?
In Firefox I had also to accept the security issue, but then at least I was able to stream again my videos…
The “security issue” only occurs when you use the local version of the web app. Which is not loaded via https.
Work around that by using the hosted version from https://app.plex.tv
By using Brave browser, you need to keep in mind that you are using a browser which has been kneecapped. It’s like intentionally blinding yourself, but blaming your optician that you cannot see correctly.
I’m running my Plex Media Server off of a Synology DS218+ with the latest DSM version DSM 6.2.4-25556 Update 2
The Plex Media Server version is 1.18.5.2309-f5213a238
The Plex Android app version is 8.23.1.28053
The issue is affecting my Android app both from inside my home network, as well as from outside. I’m using a Let’s Encrypt certificate on my Fortigate firewall to secure the https connections to my Synology NAS, both for management, as well as for Plex access.
The issue started happening out of nowhere.
OK, I tried with Firefox inside my home network.
I entered the URL https://myfqdn-nas.synology.me:32400/web
Firefox is complaining about invalid certificate, because HSTS is in place: the certificate is valid for *.some-weird-string.plex.direct
Could it be that a Synology NAS firmware upgrade started enforcing HSTS and now I’m getting issues? This is actually strange, because I upgraded the NAS 19 days ago and the issue appeared only last week…
This will never work, because you are requesting an encrypted connection (https) with a domain name which doesn’t have a cryptographic certificate attached to it.
To access your Plex server always use either https://app.plex.tv
or in the local network
http://ip_of_your_nas:32400/web
Or get a proper (i.e. publicly trusted, not self-signed) certificate for your custom domain name.
Of course my FQDN is not “myfqdn-nas.synology.me” - I don’t want to share my FQDN here in this forum, but I can guarantee that I do have a valid SSL certificate (Let’s Encrypt).
Of course with the IP and without SSL, it works - so @FordGuy61 is right pointing at the incompatibility between PMS 1.18 and the actual Android app.
So I manually upgraded to the latest 1.24.3.5033-6000 and in fact now my Android app works again!
So one thing is fixed.
Now, when I try accessing the URL on port :32400/web (via http), it redirects me to https and then fails because of HSTS.
Any solution to this?
I’ll defer to others on the other issue. My comment was strictly in regard to the Android problem, and I use app.plex.tv, not a personal domain name, when accessing my server via Plex Web.
Well, now that I think about it: when I’m abroad on another computer, I just use plex.tv and log in there and I can reach my PMS…
I think it’s a non-issue the one related to the URL:32400/web URI… but maybe somebody knows how to fix that as well…
Thanks so far!
