Anyway of changing the Genre.
I have some movies with the genre Sc-Fi and others with Science Fiction. Is there a way to change them so they are all the same ? Do I assume correctly that this info is obtained from the metadata ?
you assume correctly.
and you’re free to overwrite the Genre!
pro-tip… to avoid checking every single video for genre names you don’t like, you can use a filter.
filter by the genre name you want to change and edit only those videos (optionally you should even be able to mass-edit the items when filtered!
Thanks. You explained it so even I could understand. (and thats quite a challenge).
