API for Publishing Port to MyPlex
So i have a working C# library for interacting with MyPlex and I use it to do some things on my PMS install. I am wondering if I can publish my servers port to myplex, the problem I am having is my ISP drops my connection sometimes and my pms install won't republish the port to myplex when the connection comes back and I am using the local authentication so after the internet comes back no one can use the pms install unless I manually reconnect the port. I'd like to write a little app that check if the connection has dropped and then when it comes back to push the port number to myplex. Is there an API I can use?
