Youtube is gone from the menu. I will run plexconnect Apple TV update? Certificates do I need to install again?
Sory bad english.
Sory bad english.
no need to re-do certificates.
but not sure how plexconnect is related to youtube
Thanks for the info.
I'm using third-generation Apple TVs and My updates are turned off
Maybe if I update will be fine.
But I'm afraid that if I have to update the Apple TV plexconnect will not run.
It should run. But you can also install this Plex channel -> https://forums.plex.tv/topic/160562-rel-youtubetv-alternative-youtube-plugin/
Thank you to everyone. 7.2 update I did. plexconnect works fine and YouTube :)
