Youtube does'nt work ?
Hello,
Sory for my bad english.
Why youtube chanel does’nt work with plex connect?
Because the dns changes?
We can’t use youtube chanel without change the dns number ?
Thanks.
YouTube channel does work perfectly fine with PlexConnect, I use it all the time.
What happens if you reboot the ATV with the DNS pointing to PlexConnect ?
Ok , im going to reset my appletv3 and configure again all.
Thank you.
Another question, what is the procedure with the new firmware 7 ?
Easy method - switch DNS to auto and update right from aTV to new iOS.
Hard method - hook to iTunes and update using DFU with a new ATV ipsw.
http://www.youtube.com/watch?v=DkLNldbvExs
The easy method should preserve your settings (native app logins, ATV certs). The hard method would require you to re-enter everything back into ATV.
