Apple TV 4K 18.1 Plex - your connection is not fast enough
Server Version#: 1.41.9057
Player Version#: 8.41 (9404)
When plays some video with default settings (Convert automatically) video get stuck very fast (Doesn’t matter if I have Plex pass with hardware decoding - it is just delay the moment)
But when choose Play Original Quality - it never happens
Both logs attached (Apple TV and Server)
Plex Media Server Logs_2024-11-09_09-44-43.zip (4.1 MB)
Apple tv logging.zip (1.2 MB)
Video file info
videofile.xml.zip (4.2 KB)
P.S. For logs - it happened in last 10 minutes before I downloaded logs
I have the same problem I would like to try the beta version to see if the problem persists. In the meantime I use VidHub but I much prefer the plex app and I have the plexpass.
I have the same problem with Apple TV version 8.42 with UNRAID plex server version 1.41.1.9057. I have another Apple TV that is running version 8.29 that works perfectly. Something broke between 8.29 and 8.42. It only plays for a few minutes and then stops and says the connection is not fast enough.
Please fix this!
Same problem. Tried everything. It’s worked for years then all of a sudden nothing.
which plex client settings did you use before it broke? i want to set them at least to the same, so if its fixed it works right away
