Server Version#: 1.18.8.2527
Player Version#: 2.15 (14696)
I have started to get constant buffering on certain mp4 1080p files on the Apple TV 4k. Both the server and the ATV are on LAN connections and bandwidth is not an issue.
The same MP4 plays fine on the web browser or via my iPhone 7. It is only the Apple TV player that seems to have the issue. It appears to be something specific in the container because if I turn off direct play and allow direct stream it works fine.
Likewise, if I extract the H.264 and place it into a new MP4 container it works fine (no change to bit rate or encoding)
Media Info shows the following:
Video #1
Format : AVC
Format/Info : Advanced Video Codec
Format profile : High@L4
Format settings : CABAC / 4 Ref Frames
Format settings, CABAC : Yes
Format settings, Reference frames : 4 frames
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Duration : 1 h 53 min
Bit rate : 5 178 kb/s
Width : 1 916 pixels
Height : 1 076 pixels
Display aspect ratio : 16:9
Frame rate mode : Variable
Frame rate : 23.976 FPS
Minimum frame rate : 23.077 FPS
Maximum frame rate : 25.000 FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.105
Stream size : 4.09 GiB (87%)
Title : Core Media Video
Language : English
Encoded date : UTC 2017-02-05 19:03:27
Tagged date : UTC 2017-02-05 19:04:15
Color range : Limited
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709
Codec configuration box : avcC
The server shows the client dropping and reconnecting constantly
Apr 01, 2020 19:25:22.908 [0x149da6228700] DEBUG - Request: [192.168.1.204:63583 (Subnet)] GET /library/parts/11004/1585778215/file.mp4 (12 live) TLS Signed-in Token (bletour) (range: bytes=43585253-)
Apr 01, 2020 19:25:22.912 [0x149da6228700] DEBUG - Content-Length of /Movies/Stranger Than Fiction (2006)/Stranger Than Fiction (2006).mp4 is 5008604258 (of total: 5052189511).
Apr 01, 2020 19:25:22.915 [0x149da7663700] DEBUG - Failed to stream media, client probably disconnected after 2097152 bytes: 104 - Connection reset by peer
Apr 01, 2020 19:25:22.915 [0x149da7663700] DEBUG - Completed after connection close: [192.168.1.204:63582] 206 GET /library/parts/11004/1585778215/file.mp4 (12 live) TLS 97ms 2097152 bytes (range: bytes=44378158-)
Apr 01, 2020 19:25:23.002 [0x149da7864700] DEBUG - Auth: authenticated user 1 as bletour
Apr 01, 2020 19:25:23.002 [0x149d77dfe700] DEBUG - Request: [192.168.1.204:63584 (Subnet)] GET /library/parts/11004/1585778215/file.mp4 (12 live) TLS Signed-in Token (bletour) (range: bytes=44422887-)
Apr 01, 2020 19:25:23.007 [0x149d77dfe700] DEBUG - Content-Length of /Movies/Stranger Than Fiction (2006)/Stranger Than Fiction (2006).mp4 is 5007766624 (of total: 5052189511).
Apr 01, 2020 19:25:23.010 [0x149da7864700] DEBUG - Failed to stream media, client probably disconnected after 1835008 bytes: 104 - Connection reset by peer
Apr 01, 2020 19:25:23.011 [0x149da7864700] DEBUG - Completed after connection close: [192.168.1.204:63583] 206 GET /library/parts/11004/1585778215/file.mp4 (12 live) TLS 102ms 1835008 bytes (range: bytes=43585253-)
Apr 01, 2020 19:25:23.097 [0x149da7864700] DEBUG - Auth: authenticated user 1 as bletour
Iuploaded both server and client side ZIP files.
logging.zip (1.0 MB) Plex Media Server Logs_2020-04-01_19-25-25.zip (4.7 MB)
