Apple TV will not connect
Can anyone help with ATV connection issues? I’ve canceled my paid subscription until I can get it to connect again. There are 10000000 posts here that haven’t helped. I’ve had the same setup for years and now it doesn’t connect. The server is running on OS X and works fine on the computer but none of my streaming devices will connect anymore. I don’t have logs, because it doesn’t connect. I’ve turned off all firewalls, vps, and blockers, I’ve deleted and reinstalled, I changed accounts, I changed DNS, I added IPv6, I’ve added whitelist IPs. What else is there? There is no error messages given, just can’t connect. Very useful.
There should still be logs on PMS or if you turn on Network Logging on that device. What’s your home network like?
The network is wired. Here is the log. com.plexapp.plex 2021-10-08–17-17-41-903.log (268.8 KB)
The server computer is listening on 32400
Plex\x20M 30525   joshuadorman   63u  IPv6 0x34eae6d7499727      0t0  TCP *:32400 (LISTEN)
Might be a stupid question but Is “Enable server support for IPv6” turned on?
Yes, that was suggested somewhere and I did enable it. No change.
