For some reason when using the old audio engine on my Apple TV, audio will only play through one HomePod speaker. If I use the current audio engine it works fine.
The reason why use the old audio engine is because if the new engine is on, when I press play it won’t start playing the video unless I press forward once. So if I’m just watching a Bunch of shows, it will never play the next episode. it will just stay at marker 00:00 unless I press forward once. Then it will start playing.
This doesn’t happen if I use the old audio engine. Any Ideas?
