AppleTV 4K can't see my personal Extras in TV series and Movies
Server Version#: Linux Debian with native installation of Plex Server 4.66.1
Player Version#: Apple TV 4K Plex Client 7.25 (1615)
Good morning,
I would like to know why I can’t see my EXTRA videos with the AppleTV 4K and Plex while from the iPhone they can be seen.
Is it a limitation of the AppleTV?
Extras are showing fine on my Apple TV 4K.
There’s one limitation with regards to local extras for tv shows where the Apple TV Plex client currently cannot display extras for seasons (extras for the shows themselves and episodes are displaying just fine).
When you write you cannot see them… do you mean they’re not displayed or they fail to play?
I mean I can’t see them at all, they don’t even appear.
I’ll show you my directory here :
Here instead from iPhone the Extra is seen and I can launch it safely :
On the TV with AppleTV 4K they don’t appear at all :
Not even via Safari browser they don’t appear :
As pointed out above… the Apple TV won’t show any season-level extras – only those for the show itself and individual episodes. Plex Web will only show local tv-show extras for the show.
There’s a feature suggestion to update the UI on all clients to support local extras for all tiers of a tv show. That thread also contains a summary of what clients currently support local tv-show extras and for what tiers.
Thank you, but will this be fixed in the future or will it stay like this forever?
I ask because otherwise I will be forced to move to kodi
thanks
I certainly hope so but I cannot tell for sure.
Plex don’t usually comment on their roadmap.
I’ve seen some users simply moving those season-level extras to the show level (including a season prefix in the file name – e.g. Season 1: Character Dossier - Aram Mojtabai.mkv).
Side note…
Your extra naming is redundant and might be causing some conflicts down the road. If you’re organizing extras in their own folders (here: Scenes), you don’t need to add the extra-type suffix (here: -featurette) – especially if those are conflicting types.
Example 1
Season 01
  Scenes
    Character Dossiers Aram Mojtabai.mkv
  The Blacklist - s01e01 - Pilot.mkv
Example 2
Season 01
  Character Dossiers Aram Mojtabai-featurette.mkv
Schermata 2021-12-11 alle 13.22.02
Even doing so only works from iPhone but from AppleTV the extras don’t appear.
True. I didn’t say this will make them appear on the Apple TV – just pointing out a potential hiccup
