Server Version#: 1.40.2.8395
Player Version#: 8.35 (AppleTV app)
Unraid Version#: 6.12.10
This has seemingly been a bug for ages - had hoped that updates would fix it since it did work initially.
The issue:
When I start playing a series, at the end I would press back and be presented with the “Play next” screen. In some cases it would perform a countdown that I can then skip to play the next episode. In these cases it works fine. However, after every second episode or so the countdown timer no longer appears and only a play option is available - problem is, selecting the episode to play does nothing. I can see the animation when selecting the next episode to be played, but it does nothing. Only way to fix this is to go back to the series screen and select the next episode myself. While not a large issue, having to constantly do this is getting rather stale.
Had a browse on google and looks like this is a somewhat popular issue not limited to AppleTV.
Things I tried:
- Removed + added plex server container
- Deleted + reinstalled AppleTV app
(yes, turned off and on again - no difference)
Both of these solutions had no effect. Pretty sure this is a bug, since the episodes can play normally (when it works), but then behaves differently over time. So, a buglet.
