Does Plex on Apple TV support number inout from Harmony remotes?
I set up live tv with an HDHomeRun and it works, but changing channels is a PITA. I have to scroll up and down through 70 channels.
Is there a way to use it like a regular tv & enter a channel number? Is there maybe some extra work to do on the Logitech side?
JCHH
June 8, 2021, 2:21pm
2
Yes in that the Harmony remote supports Apple TV.
There are no channel numbers, so not sure exactly what you mean by this. You can do everything on the AppleTV that the AppleTV remote can do (except Sir)).
I mean press the number 7 button and have Plex change to channel 7, like you do on a normal tv.
Or is going to the guide and scrolling up and down the only way to change channels in Plex on an AppleTV?
JCHH
June 8, 2021, 3:58pm
4
Agh, got it.
No clue, I’m afraid. I set it up for my parents so cannot try that out,
No, that’s not something that’s possible at this time, I’m afraid.
Thanks for the info folks.
I’m about to ditch DirecTV and go full Plex & streaming. I guess this is a small inconvenience to save $170/mo
system
Closed
September 6, 2021, 5:53pm
7
