AppleTV / Plexconnect issue
OK this is quite a slow process as I am travelling / my brother has asked me to take care of it even though he is local and my father is not really computer literate but here is what I have just managed to discover.
1. The server is working....my father can watch movies via his iPhone
2. I believe he can also share the screen of his iPhone to his ATV
3. The route to the Plex Movies via the Trailers AVATAR is broken (see first post)
Before trying new things I thought to revisit previous checks to see if anything had changed:
COMMAND   PID           USER   FD   TYPE             DEVICE SIZE/OFF NODE NAME
mDNSRespo  42 _mdnsresponder   97u  IPv6 0xa895102a80938649      0t0  UDP *:domain
mDNSRespo  42 _mdnsresponder   98u  IPv4 0xa895102a80fab6f1      0t0  TCP *:domain (LISTEN)
mDNSRespo  42 _mdnsresponder   99u  IPv6 0xa895102a6bea2011      0t0  TCP *:domain (LISTEN)
Python    214           root    4u  IPv4 0xa895102a6bab9589      0t0  UDP macbook-pro:domain
macbook-pro:~ gema$
So Python is still active
Next we checked LauchDaemons:
cd /Library/LaunchDaemons
macbook-pro:LaunchDaemons gema$ pwd
macbook-pro:LaunchDaemons gema$ ls
com.adobe.fpsaud.plist
com.logmein.logmeinblanker.plist
com.logmein.logmeinserver.plist
com.logmein.raupdate.plist
com.microsoft.office.licensing.helper.plist
com.plex.plexconnect.bash.plist
com.trusteer.rooks.rooksd.plist
plexconnect still there
Now we tried to remove this from LaunchDaemons:
macbook-pro:LaunchDaemons gema$ sudo launchctl unload /Library/LaunchDaemons/com.plex.plexconnect.bash.plist
launchctl: Error unloading: com.plex.plexconnect.bash
Why has that failed please and what should we try next ?
If you go in the Plexconnect/support/OSX folder via terminal you can enter the following:
sudo ./uninstall.bash
This should get rid of it for you.
Thanks....what is the explicit path to that folder please ?
It depends upon what you called you PlexConnect folder and where you placed it e.g. in applications.
I find it useful to add an open terminal here to the right click services menu:
http://lifehacker.com/launch-an-os-x-terminal-window-from-a-specific-folder-1466745514
OK we should be able to make faster progress....my brother has opened up my Dad's machine to me remotely with:
http://www.teamviewer.com/en/download/mac.aspx
I can now directly access the machine instead of sending him commands via Skype Chat which was a pretty tortuous
I have now bumped into the following......see attached
ah wait....wrong folder
Now from the right folder
some more checks
If you try and launch PlexConnect now does it give you the port 53 error?
Is internet sharing turned on on that Mac?
See attached
Looks like the permissions on the folder are out of whack, do a chmod on them to 777.
Internet sharing can cause issues, is it needed?
Catch 22 I think !! Internet sharing is likely enabled so that I can remotely access the machine from Team Viewer which is how I am collecting this data
Which precise folder are you suggestions I open permissions on ?
Just st do it to the whole PlexConnect folder and its sub folders.
Internet sharing shouldn’t be needed for team viewer access.
Thanks for the suggestions !
  • Sharing is now off
  • Permissions changed
However I still cannot run the Plexconnect Python script
Doh, i think you are trying to run it without using the "sudo" command.
Should have caught that earlier!
See what I got.....need to read the screenshots in reverse timestamp order
So are they still getting trailer unavailable, even after rebooting the ATV?
Btw you are better attaching the plexconnect.log (found in the main folder) for troubleshooting rather than screenshots of the terminal window output, which might not hold enough information?
Have not had the ATV rebooted so not sure on the first one but can ask my Dad to do that and then try again
Here is the log....have now figured out how to do the File Transfer from TeamViewer
I re-ran the Python Script and he restarted ATV....he still gets:
TRAILERS is unavailable
Here is the log
Even if you are not getting Plex to work in the trailers app you should still be seeing DNS requests from the other applications (PlexConnect just forwards these to allow the applications to work as usual).
Are the other apps on the ATV working? If they are then i would say that the ATV does not have its DNS pointing to PlexConnect (192.168.0.7).
