Are these Bugs!
I have found some quirks that I think are bugs:
  1. When adding a poster to a Collection or movie the slider in windows does not work and the slider in Windows explorer does not work, but you can move up and down the folder and file panes, but you can’t open the chosen file to update the poster. However you can use drag and drop to change the picture, but to clear the open window you have to close Plex.
  2. When choosing a collection name (that you have already created) you can’t see the dropdown list as the window-pane created is too small. It just needs the size of the pane to be extended!
There does not seem to be a way to report bugs directly to Plex, so I am mentioning it here hoping that they monitor this forum.
