Exactly what the title is. Are we done with Changing Posters? Can I go through and change them back to what they were previously without them automatically being changed again? Are we in the clear?
I believe you can lock in the poster you like per title and it should not change. At least that is the way it is supposed to work. As far as getting your old poster back, all I can say is see and if not, go find the jpg or whatever you want and manually load it.
Eventually they’ll apply Gracenote default posters to TV show libraries too so those will probably have the same thing happen if you don’t manually select posters ahead of time (to lock them).
But Movie posters shouldn’t be changing anymore unless they were picked as other source posters and those sources changed them (which was rare but happened with TMDB default posters if you didn’t manually select one).
