Server Version#: Version 1.19.4.2935
Player Version#: dna
Title explains. I tried multiple shows, not just the one that needs to be fixed, and none offer the Fix option anymore. Or the Match option at all.
Try at the Show level, instead of the Season level.
Was it always like that? i swear I have fixed shows from the Home tab. Maybe I haven’t and just didn’t realize. Duh, on me, and thank you.
It’s always been like that (well… for years). Keep in mind, the home tab does not necessarily point to the entire show but e.g. a newly added episode or season. Where it points to the show record, you should also be able to trigger a fix-match – just not for those other instances where the home tab points to some other level.
Fair enough. That would make sense, since it was only looking at season level on home page, not show level. Most likely why I thought I had fixed it before, it was at show level then for whatever I may have fixed the match in the past. I just never paid it that much attention which led me to asking a pretty easy question that my dumb butt should have just looked further into and figured out.
