Match / Fix match missing?
Server Version#: 1.31.1.6733-bc0674160 (QNAP)
In the more section (…) of my series & movies all of a sudden I cannot see match or fix match in the menu anymore (analyse, optimise etc are there). Any hints or clues ?
Those options aren’t there in the posters you select from the home screen like the Recently added row
You have to be inside the library view
The reason there’s no Fix Match option in the Recently Added hub is that those are usually seasons or individual episodes. Fix Match only works on a show level – so no Fix Match option if you see a season/episode. The option is working fine for me on the home screen on all actual show and movie entries.
@KoffieNT : where exactly are you trying to trigger Match or Fix Match (and on what type of item)? – your post isn’t clear about that to me.
In the library → series , so on the highest level (not on episode or season level).
Just downgraded firmware to 1.30 and I can see the match and fix match options again.
Thank you for the help
