Has the ‘Fix Match’ option been removed in the latest plex update?
I seem to can’t find it anywhere. If there is a new alternative option what is it?
It’s still there, accessible from…
... > Fix Match when hovering over the poster)... > Fix Match)If you’re trying to fix match of a single episode or season, you can’t.
It is only available at the top “show” level.
… and if your file names are so bad you have to fix every episode - after you’ve fixed the main show…
that’s some exemplary bad file naming.
I dont have the Fix Match option anywhere for a particular show.
Whereas in other shows the Option comes up ok
What could be the issue?
Thanks for any help
Thank you so much for the nudge… I was being a bit blind… Thx a lot
omg, thank you. I have been struggling with this for months, literally. wow. so easy.
