Hello,
is it possible to change the default view when I click on the artist?
For instance, albums are placed horizontally, and I have to scroll with little arrows. In my case it’s “Soundtracks” that is horizontal.
It would be way nicer to have a vertical list of everything, this way it is terrible UI really.
Any way to change this?
Kosta
My knee-jerk response is to suggest that you use the Plexamp client for your music consumption needs. It does what you’d like; when you select an artist, it shows all of their albums without needing to scroll horizontally. But it also has some other excellent music discover options. (I’m particularly fond of Sonic Adventure; input some songs you’d like to hear and it will fill in the gaps with other similar songs.)
Thanks but… that’s so poor. When listening, managing playlists and creating new, website (or Plex app) is a must on a laptop, in my case a Macbook. PlexAmp is of course good for listening, I use it both on the macbook and iphone for simple listening.
