Server Version#: Latest
Hello. I would like to know if there is the possibility for a movie library to have The poster and movie title in English language and metadata in other language (Greek in my case). It’s more convinient to search with english titles and also find the correct matches but having all the plot etc in native language. Also many times when I search movies in Greek they don’t match if the Title is in Greek
No, that is not possible. You can only define one language for all metadata.
You could disable “Localized titles” in the properties of your movie library. However, this may mean that you will see japanese titles on movies from Japan.
Thanks for the reply. I don’t see the “Localized titles” anywere in the properties of my library. I must use the Plex movie to see it? I am usind the movie database agent
Is it possible to change the agent to Plex movie for the already scanned items in my library without losing my data (seen movies etc)?
This option is only available with Plex Movie, yes.
This is only possible when using “Fix Match” on each single item separately.
i.e. it is not practically possible.
