I am setting up a new AS1004T v2 but am unable to successfully get to Plex. Get browser error : Unable to connect. I’ve uninstalled and reinstalled several time to know avail. My DDRT router is seeing the app and appears be providing correct UpNP:
|app#Plex Media Server|Yes|32400|32400|192.168.90.148|TCP||
|app#Plex Media Server|Yes|32400|32400|192.168.90.148|UDP||
It appears the installation is corrupted. Here is server log.
Oct 03, 2021 17:21:31.085 [0xb3b69d48] INFO - Plex Media Server v1.24.3.5033-757abe6b4 - ASUSTOR AS1004T armv7l - build: linux-armv7neon asustor - GMT -07:00
Oct 03, 2021 17:21:31.086 [0xb3b69d48] INFO - Linux version: ADM 3.5.7.RKU2, language: en-US
Oct 03, 2021 17:21:31.086 [0xb3b69d48] INFO - Processor Arm
Oct 03, 2021 17:21:31.086 [0xb3b69d48] INFO - Compiler is - Clang 11.0.1 (https://plex.tv e0c29d5827bc4eaaa2ceb882cbeed224b0960173)
Oct 03, 2021 17:21:31.086 [0xb3b69d48] INFO - /usr/local/AppCentral/plexmediaserver/Plex Media Server
Oct 03, 2021 17:21:31.080 [0xb6d29e80] DEBUG - BPQ: [Idle] → [Starting]
Oct 03, 2021 17:21:31.082 [0xb6d29e80] DEBUG - Opening 20 database sessions to library (com.plexapp.plugins.library), SQLite 3.35.5, threadsafe=1
Oct 03, 2021 17:21:31.082 [0xb6d29e80] DEBUG - Installing Library Database from ["/volume1/.@plugins/AppCentral/plexmediaserver/Resources/com.plexapp.plugins.library.db"] to ["/volume1/Plex/Library/Plex Media Server/Plug-in Support/Databases/com.plexapp.plugins.library.db"]
Oct 03, 2021 17:21:31.082 [0xb6d29e80] ERROR - Couldn’t copy file “/volume1/.@plugins/AppCentral/plexmediaserver/Resources/com.plexapp.plugins.library.db” to “/volume1/Plex/Library/Plex Media Server/Plug-in Support/Databases/com.plexapp.plugins.library.db”: Invalid argument
Oct 03, 2021 17:21:32.312 [0xb6d29e80] DEBUG - Running migrations. (EPG 0)
Oct 03, 2021 17:21:32.312 [0xb6d29e80] ERROR - SQLITE3:(nil), 1, no such table: schema_migrations in “select version from schema_migrations order by version”
Oct 03, 2021 17:21:32.312 [0xb6d29e80] ERROR - Database corruption: sqlite3_statement_backend::prepare: no such table: schema_migrations for SQL: select version from schema_migrations order by version
Oct 03, 2021 17:21:32.312 [0xb6d29e80] ERROR - Error: Unable to set up server: sqlite3_statement_backend::prepare: no such table: schema_migrations for SQL: select version from schema_migrations order by version (N4soci10soci_errorE)
