Greetings,
I have an asustor as1002t v2 with ADM version 3.5.7.RKU2 and I installed plex media server app via App Central.
However, plex won’t start. I tried uninstalling and reinstalling, but the result is always the same.
This is what the log file says:
Oct 10, 2021 14:23:43.205 [0xb3ba2d48] INFO - Plex Media Server v1.24.3.5033-757abe6b4 - ASUSTOR AS1002T armv7l - build: linux-armv7neon asustor - GMT 01:00
Oct 10, 2021 14:23:43.207 [0xb3ba2d48] INFO - Linux version: ADM 3.5.7.RKU2, language: en-US
Oct 10, 2021 14:23:43.207 [0xb3ba2d48] INFO - Processor Arm
Oct 10, 2021 14:23:43.207 [0xb3ba2d48] INFO - Compiler is - Clang 11.0.1 (https://plex.tv e0c29d5827bc4eaaa2ceb882cbeed224b0960173)
Oct 10, 2021 14:23:43.207 [0xb3ba2d48] INFO - /usr/local/AppCentral/plexmediaserver/Plex Media Server
Oct 10, 2021 14:23:43.188 [0xb6d62e80] DEBUG - BPQ: [Idle] → [Starting]
Oct 10, 2021 14:23:43.259 [0xb6d62e80] DEBUG - Opening 20 database sessions to library (com.plexapp.plugins.library), SQLite 3.35.5, threadsafe=1
Oct 10, 2021 14:23:43.358 [0xb6d62e80] DEBUG - Running migrations. (EPG 0)
Oct 10, 2021 14:23:43.358 [0xb6d62e80] ERROR - SQLITE3:(nil), 1, no such table: schema_migrations in “select version from schema_migrations order by version”
Oct 10, 2021 14:23:43.358 [0xb6d62e80] ERROR - Database corruption: sqlite3_statement_backend::prepare: no such table: schema_migrations for SQL: select version from schema_migrations order by version
Oct 10, 2021 14:23:43.358 [0xb6d62e80] ERROR - Error: Unable to set up server: sqlite3_statement_backend::prepare: no such table: schema_migrations for SQL: select version from schema_migrations order by version (N4soci10soci_errorE)
I’m installing it from the admin account.
How can I get plex running on the nas, please?
EDIT: update- I have installed the new ADM update (4.0.0.RMD2), uninstalled plex and reinstalled. It now installed properly. However, it won’t open the page properly with my DDNS address. That’s a separate issue, though, so I’ll try to fix it and if I can’t I’ll collect data for another post.
