I’ve just got my first Android TV, a Philips Ambilight 75PUS7803/12. I’ve been using Plex on my Samsung Smart TV for over a year with absolutely no problems, however on this Philips TV I’m having very strange issues with the aspect ratio.
Some films and TV shows, but not all, are squished vertically. For example if there are black bars at the top and bottom playing on the web app and on my Samsung TV, the black bars double in size and the footage is condensed on the Philips. These are the exact same files using the exact same server.
Server Version#: Version 1.14.1.5488 installed on WDMyCloud Mirror
Player Version#: 7.12.2.2.9471
Has anyone encountered this before or could anyone offer any advice? It’s driving me crazy!
I’m “glad” I’m not the only one with this problem. I have Philips 55PUS8303 and most of the movies are now unwatchable. 3 month ago I still played many of them on Sony Bravia 55 KDL-W808C (2015) and the aspect ratio was just fine. Now the majority of movies are shown in 1.85:1 ration or perhaps even 2.39:1. I tried with VLC player where the aspect ratio can be adjusted but the audio is out of sync :-(.
I have the same prblem. I try to reinstall the firmware but the Android system tell me that it can’t be downgrade or install the same version, so… I cant try your solution.
I have exactly the same problem on my 65OLED873/12.
Plex has always worked great until the last update in which the aspect ratio has halved and any film is now unwatchable. The plex TV and app are updated to the latest versions available. How to solve?
update for those who have a philips andorid tv.
if you search for the plex server via “network” and not from the plex player everything works fine.
no double bar is displayed and the content retains its aspect ratio
Hi
55POS9002/05 owner here with exactly the same problem. I’ve tried casting from my phone using the Plex app and get the same squashed aspect ratio. I’m running the latest Android software on the TV (Oreo).
I’m having to watch my Plex films on my PC
Hi, also have the same issue with double black bars on my 55POS9002.
Things tried;
Installed PM171E_107.0.230.0 - no change.
Reinstalled TV (menu option) - no change.
Reinstalled TV again - no change.
Aspect ratio is fine when;
Playing using Media app and browsing the plex server, as suggested by @strike_c.
Casting from iOS Plex app using Google Cast. (Plex remote in the app does not work).
To me it seams like this is an issue with the player app on Android TV 8.
I also got big issues with audio passthrough (tv setting) with Oreo, that gives a few seconds of out of sync audio - way past whats correctable with all the available settings.
Hello
Same problem for me with a Philips 55POS9002/12
The firmware is updated to latest version, released March, 3rd. Tried to uninstall and reinstall the Plex app but the wrong aspect ratio problem persists.
And as others said, all was fine before the latest Philips Android / firmware update
Maybe it’s the Plex app that has to be updated
All my movies are on a QNAP NAS and they are played with correct A/R by other media players on the same TV, e.g. Serviio
This really need an update from Philips and/or Plex
To reinstall the latest firmware you have to download it and copy the file inside the .zip to an USB drive. Insert the usb stick in the tv and the installation will start automatically.
I just did that and it fixed the issue.
