Server Version#:1.32.3.7192
Player Version#: Plex for Samsung 5.62.0
Hi, I often watch TV shows and they come with many audio tracks. These tracks are normally done in the same order in each file of the season of the TV show. They are not always properly created and it is thus not possible to say which language they are in. Normally if they are created correctly, my global setting of choosing English as a priority would trigger and there’d be no issues. If they are not, though, it does not trigger and the first track in the queue would be applied. Once you change the track it is saved for this exact episode, but the next one starts anew and you have to apply the correct track to the next episode.
It would be great to have the ability to suggest to automatically apply the same track number in all the other episodes of the season once I select it. I understand it would work only if number of tracks in the other files is the same. But this is so in 99% of cases. WDYT?
