Hello,
I have an old Ati remote wonder ii (usb radio remote control) that i used in my Geexbox years a while ago.
I was wondering if it could be possible to use it as a remote control for Rasplex…
Anybody tried?
Thks
Valyno
Check if your remote is supported by OpenELEC and just follow their instructions if available.
Hi a_wein,
Thank you for the tip!
It is supported by openelec, but not fully -i.e not ll the buttons).
However, I digged out the remote from the storage box it was in and I plugged it on my fresh received Pi...
Tadaa: the arrows are working, play, pause, "e" as Esc and the volume.
So the basics controls are ok.
I wish I could get access to the "m" for menu, or the "i" for the flux information..
The remote has Menu button, working oob to replace the "m" keystroke !
"i" is still missing...
I will do some extra searches to see if this can be mapped...
