ATV 2G Plex command prob.
can someone please give me the latest commands for the Plex installation?
The ones I use does not work. I get into the ATV and I enter the first 4 commands then I get errors. On command 5 plex never gets installed.
Below are the commands I have used.
Update Settings:
http://localhost:32400/system/:/prefs/set?AS_BETA=1
Command 1.
ssh root@169.10.11.12
Command 2.
echo "deb http://apt.awkwardtv.org ./" > /etc/apt/sources.list.d/awkwardtv.list
Command 3.
echo "deb http://www.ambertation.de ./downloads/PLEX/" > /etc/apt/sources.list.d/plex.list
Command 4.
apt-get update
Command 5.
apt-get install plex-client-plugin
Command 6.
killall Lowtide
This is a hack and not an official implementation of plex. It is more of a proof of concept then anything.
You really should use the official thread for this: http://forums.plexapp.com/index.php/topic/20051-plex-client-for-apple-tv-2g/page__hl__apple+tv2
(When you repost over there, detailing the errors you get would be most helpful… :))
Hi !
I’ve just visited this forum. Happy to get acquainted with you. Thanks.
__________________
Watch Online Movies
