12:22:46 PlexConnect: ***
12:22:46 PlexConnect: PlexConnect
12:22:46 PlexConnect: Press CTRL-C to shut down.
12:22:46 PlexConnect: started: 12:22:46
12:22:46 PlexConnect: Version: 0.5-dev-110616
12:22:46 PlexConnect: Python: 2.7.8 (default, Jun 30 2014, 16:08:48) [MSC v.1500
64 bit (AMD64)]
12:22:46 PlexConnect: Host OS: win32
12:22:46 PlexConnect: PILBackgrounds: Is PIL installed? False
12:22:46 PlexConnect: IP_self: 192.168.1.115
12:22:47 DNSServer: started: 12:22:47
12:22:47 DNSServer: ***
12:22:47 DNSServer: DNSServer: Serving DNS on 192.168.1.115 port 53.
12:22:47 DNSServer: intercept: [‘trailers.apple.com’] => 192.168.1.115
12:22:47 DNSServer: restrain: [‘mesu.apple.com’, ‘appldnld.apple.com’, ‘appldnld
.apple.com.edgesuite.net’] => 127.0.0.1
12:22:47 DNSServer: forward other to higher level DNS: 8.8.8.8
12:22:47 WebServer: started: 12:22:47
12:22:47 WebServer: Failed to connect to HTTP on 192.168.1.115 port 80: [Errno 1
0013] An attempt was made to access a socket in a way forbidden by its access pe
rmissions
12:22:47 WebServer: Failed to connect to HTTPS on 192.168.1.115 port 443: [Errno
10013] An attempt was made to access a socket in a way forbidden by its access
permissions
HI
I knew i had done something like that in the past but was not sure til you mentioned it.
I have just tried and get back an error no idea what to do ??
login as: root root@192.168.1.105’s password:
Family-Room-Apple-TV:~ root# apt-get -y install git; rm -R /Applications/atvjailbreak; cd /Applications; git clone git://github.com/wahlmanj/atvjailbreak.git; cd /Applications/atvjailbreak; ./installatv.bash
Reading package lists… Done
Building dependency tree
Reading state information… Done
You might want to run apt-get -f install' to correct these: The following packages have unmet dependencies: git: Depends: expat but it is not going to be installed rtadvd: Depends: firmware (< 9.0) but it is not installable sqlite3-lib: Depends: firmware (>= 3.0) but it is not installable or sqlite3-dylib but it is not going to be installed uikittools: Depends: firmware (< 8.3) but it is not installable or com.saurik.patcyh but it is not going to be installed E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution). rm: cannot remove/Applications/atvjailbreak’: No such file or directory
-sh: git: command not found
-sh: cd: /Applications/atvjailbreak: No such file or directory
-sh: ./installatv.bash: No such file or directory
Family-Room-Apple-TV:/Applications root# apt-get -y install git; rm -R /Applications/atvjailbreak; cd /Applications; git clone git://github.com/wahlmanj/atvjailbreak.git; cd /Applications/atvjailbreak; ./installatv.bash
Family-Room-Apple-TV:/Applications root# ^C
Rebooted my modem and server and tried again and it has worked no idea why.
So onto my next issue I have the Plex icon and i have logged in and connected with PMS one in the home and Amazon Cloud.
All my content is there and accessible all until i try to play one! The player comes on to start then just stops and screen goes black or it sticks on 1st frame of show/film.
I have triyed to install plexconnect with no success.
Can you please help me??
thanks
This is what I get:
Apple-TV:~ root# apt-get -y install git; rm -R /Applications/atvjailbreak; cd /A pplications; git clone git://github.com/wahlmanj/atvjailbreak.git cd /Applicatio ns/atvjailbreak; ./installatv.bash
git is already the newest version.
0 upgraded, 0 newly installed, 0 to remove and 33 not upgraded.
rm: cannot remove `/Applications/atvjailbreak’: No such file or directory
Too many arguments.
usage: git clone [] [–] []
-v, --verbose be more verbose
-q, --quiet be more quiet
--progress force progress reporting
-n, --no-checkout don't create a checkout
--bare create a bare repository
--mirror create a mirror repository (implies bare)
-l, --local to clone from a local repository
--no-hardlinks don't use local hardlinks, always copy
-s, --shared setup as shared repository
--recursive initialize submodules in the clone
--recurse-submodules initialize submodules in the clone
--template <template-directory>
directory from which templates will be used
--reference <repo> reference repository
--dissociate use --reference only while cloning
-o, --origin <name> use <name> instead of 'origin' to track upstream
-b, --branch <branch>
checkout <branch> instead of the remote's HEAD
-u, --upload-pack <path>
path to git-upload-pack on the remote
--depth <depth> create a shallow clone of that depth
--single-branch clone only one branch, HEAD or --branch
--separate-git-dir <gitdir>
separate git dir from working tree
-c, --config <key=value>
set config inside the new repository
-4, --ipv4 use IPv4 addresses only
-6, --ipv6 use IPv6 addresses only
