ATV 3 and Wifi
Ok, I recently bought my new shiny ATV3, because for several reasons I had to give up my old one. Easy peasy I thought, I knew how to set it all up with seasonpass as usual. Well, then of course it seems the fruit company made it all more complicated for you guys. And for that I am very sorry.
So back to square one, trying to set up plexconnect on a ATV3 using only wifi.
I live in the US now and am using comcast so I get 2 DNS-servers. I picked one of them for connecting, and then made a manual connection to the same static IP-address I have given my laptop. Still nothing happens. If I pick trailers it wont load, and if I just let all on auto except for DNS, it wont find it.
What am I missing?
//C
00:39:51 PlexConnect: ***
00:39:51 PlexConnect: PlexConnect
00:39:51 PlexConnect: Press CTRL-C to shut down.
00:39:51 Settings: add section PlexConnect
00:39:51 Settings: add option logpath=.
00:39:51 Settings: add option enable_dnsserver=True
00:39:51 Settings: add option ip_webserver=0.0.0.0
00:39:51 Settings: add option prevent_atv_update=True
00:39:51 Settings: add option enable_plexconnect_autodetect=True
00:39:51 Settings: add option port_pms=32400
00:39:51 Settings: add option port_webserver=80
00:39:51 Settings: add option ip_plexconnect=0.0.0.0
00:39:51 Settings: add option certfile=./assets/certificates/trailers.pem
00:39:51 Settings: add option ip_dnsmaster=8.8.8.8
00:39:51 Settings: add option loglevel=Normal
00:39:51 Settings: add option ip_pms=192.168.178.10
00:39:51 Settings: add option enable_plexgdm=True
00:39:51 Settings: add option port_ssl=443
00:39:51 PlexConnect: started: 00:39:51
00:39:51 PlexConnect: IP_self: 10.0.0.3
00:39:51 DNSServer: started: 00:39:51
00:39:51 DNSServer: ***
00:39:51 DNSServer: Starting up.
00:39:51 DNSServer: intercept: ['trailers.apple.com', 'atv.plexconnect'] => 10.0.0.3
00:39:51 DNSServer: restrain: ['mesu.apple.com', 'appldnld.apple.com', 'appldnld.apple.com.edgesuite.net'] => 127.0.0.1
00:39:51 DNSServer: forward other to higher level DNS: 8.8.8.8
00:39:51 WebServer: started: 00:39:51
00:39:51 WebServer: ***
00:39:51 WebServer: WebServer: Serving HTTP on 0.0.0.0 port 80.
00:39:51 WebServer: WebServer: Serving HTTPS on 0.0.0.0 port 443.
00:39:51 PlexGDM: ***
00:39:51 PlexGDM: looking up Plex Media Server
00:39:52 PlexGDM: servers discovered: 1
00:39:52 XMLConverter: PlexGDM - PMS: 10.0.0.3:32400
Seems I requested wrong DNS first.
Now I also get this.
01:30:23 DNSServer: DNS request received!
01:30:23 DNSServer: Source: ('10.0.0.6', 55402)
01:30:23 DNSServer: Domain: trailers.apple.com
01:30:23 DNSServer: ***intercept request
01:30:23 DNSServer: -> DNS response: 10.0.0.3
Have you done the required certificate steps due to apples change from http to https?
As per http://langui.sh/2013/08/27/appletv-ssl-plexconnect/
Yeah, did that too.
Are you running plexconnect on mac or winodws, if windows, your pathway is incorrect, you must use \, not forward /
A lot of people have reported issues if they dont have the absolute path in the config file
