I have the 0.1 version of PlexConnect and it's working fine. I have not yet updated the ATV to the newest version that came during the fall. Would it be any difficulties in my now working set up with updating the ATV and then update to 0.2 verison of PlexConnect? Do I need to do any changes in my set up or can I just update and everything will work as before? If so, do I need to do anything special with trhe 0.2 up date more than download and extract? Will it find it's way on it's own? The reason for asking is that I got help installing this and just want to keep it simple. I'm using a mac mini with Mavericks and the latest version of PMS.
If you follow this it should help you out if your have any issue with upgrading on osx, I would try the install wiki first.
https://github.com/iBaa/PlexConnect/wiki/Install-guides
https://forums.plexapp.com/index.php/topic/80703-plex-media-server-plexconnect-startup-scripts-for-osx/?p=464735
You have 0.1 and it is working fine? Really? Where did you hide your aTV for the last 4 months?
Sorry, I wrote wrong. I have 0.2 and wonder about the 0.3 beta update. Is there a point in doing that and will the recent ATV update plus 0.3 give me so much more than I have today?
0.3 doesn't exist yet but you will get advantages to updating to the current code if you check the roadmap:
Complete:
- MyPlex / shared content support
- Multi user support
- Now playing support
- Trailers for movies
- Ability to run PlexConnect as a daemon on Linux
- Use 'iMovie Theatre' or WSJ app instead of 'Trailers' app
- Use PlexConnect to add SSL cert to ATV
Underway:
- Ability to run PlexConnect as a daemon on OSX
- GUI improvements
