ATV 7.0 OTA UPDATE WORKING WITHOUT ISSUE
I carried out the OTA update earlier this morning.  PlexConnect works fine for me with no issues from my Hack Media server running Mavericks.
No problems what so ever.  Infact it feels faster.
Anyone experiencing any issues?
does that mean that i can update my apple tv tonight and plex will continue to connect back to the plex server without issues? sorry im a noob at this.
     PlexConnect on ATV 7.0 GM (iOS 8.0 GM)
If you looked at this topic there is a issue hijacking iMovie. WSJ and trailers and possibly others work ok still.
-Edit a fix may be found for the new iOS, same topic.
So the short answer is: YES Plexconnect still does work with the latest aTV 7.0 update if you are using Trailers as the hijack and by working I mean no need to redo the cert's to get it working.  Is this correct?
Yes.
The ATV update released yesterday had no impact on PlexConnect performance.  Except, maybe like wahlman.j highlighted, it seems faster.  For an ATV 2 & ATV 3, I'm running:
1. Mavericks V10.9.5 on a late 2011 MBP with 2.2 GHz Intel Core i7 processor
2. Airport Extreme V7.7.3
3. OpenPlex V1.0
4. PlexConnect V0.3.1+
5. PMS V0.9.10.1.585-f31034e
What did I do...?
1. Reset ATV to factory settings
2. Updated ATV Software
3. Logged in to: iTunes, iCloud and activated Home Sharing
4. Loaded Trailers Certificate using the Network process (http://xxx.xxx.xxx.xxx/trailers.cer
5. Modified DNS server to PlexConnect/PMS IP address (xxx.xxx.xxx.xxx)
It is a beautiful thing.  Thank you team, you are superstars!
