atv settings go back to default
hi,
when i change the settings on my atv3 (force transcode, subtitle size etc) the settings only remains as long as i don’t restart my computer. when i turn my computer on again i have to redo my settings on my atv.
i have tried both the xml_templates and the master release.
anyone know how to keep the settings?
/johan
You have to do a "nice" shutdown of PlexConnect - ie. press CTRL-C. With this it has a chance to store the settings in the ATVSettings.cfg file.
thanks! if i do this once, are the settings saved so i can go back and do my not so nice shutdowns?
yes... unless you want to change your settings again. :-)
Might be a good idea to save the settings every time a "SettingsToggle" command is processed by XMLConverter.py
Yes, I think we had a discussion about that in the "daemon" section... We might want to go that route.
hmm… i did a nice shutdown but now it’s back to default. i still use xml_templates because it has been working fine. is it a bug in that version?
