ATV3 6.0 & Plex
Hallo erstmal,
ich bräuchte da mal etwas Hilfe :(
Ich habe mir einen ATV3 gekauft, welches leider die Version 6.0 hat. Ich würde gerne natürlich gerne Plex zum laufen bekommen, nur stellt sich das leider nicht so einfach dar.
PC OS: Win7
ATV3: 6.0
Plex Media Server: 0.9.8.14.263-139ddbc
Anbei mal die Log:
19:04:55 PlexConnect: started: 19:04:55
19:04:55 Settings: getsetting enable_plexconnect_autodetect=True
19:04:55 PlexConnect: IP_self: 192.168.192.3
19:04:55 Settings: getsetting port_webserver=80
19:04:55 Settings: getsetting hosttointercept=trailers.apple.com
19:04:55 Settings: getsetting enable_dnsserver=True
19:04:55 DNSServer: started: 19:04:55
19:04:55 Settings: getsetting port_dnsserver=53
19:04:55 Settings: getsetting ip_dnsmaster=192.168.192.1
19:04:55 Settings: getsetting prevent_atv_update=True
19:04:55 DNSServer: ***
19:04:55 DNSServer: DNSServer: Serving DNS on 192.168.192.3 port 53.
19:04:55 DNSServer: intercept: ['trailers.apple.com'] => 192.168.192.3
19:04:55 DNSServer: restrain: ['mesu.apple.com', 'appldnld.apple.com', 'appldnld.apple.com.edgesuite.net'] => 127.0.0.1
19:04:55 DNSServer: forward other to higher level DNS: 192.168.192.1
19:04:55 Settings: getsetting enable_webserver_ssl=True
19:04:55 WebServer: started: 19:04:55
19:04:55 WebServer: ***
19:04:55 WebServer: WebServer: Serving HTTP on 192.168.192.3 port 80.
19:04:55 ATVSettings: init class CATVSettings
19:04:55 ATVSettings: load settings
19:04:55 Settings: getsetting port_ssl=443
19:04:55 Settings: getsetting certfile=./assets/certificates/trailers.pem
19:04:55 WebServer: WebServer: Serving HTTPS on 192.168.192.3 port 443.
19:05:01 DNSServer: DNS request received!
19:05:01 DNSServer: Source: ('192.168.192.6', 62800)
19:05:01 DNSServer: Domain: trailers.apple.com
19:05:01 DNSServer: ***intercept request
19:05:01 DNSServer: -> DNS response: 192.168.192.3
19:05:07 PlexConnect: Shutting down.
19:05:07 WebServer: Shutting down.
19:05:07 ATVSettings: save settings
19:05:11 DNSServer: Shutting down.
19:05:11 PlexConnect: shutdown
Settings.cfg
[PlexConnect]
port_pms = 32400
port_webserver = 80
ip_plexconnect = 0.0.0.0
certfile = ./assets/certificates/trailers.pem
ip_dnsmaster = 192.168.192.1
loglevel = High
enable_dnsserver = True
logpath = .
ip_pms = 192.168.192.3
enable_plexgdm = True
hosttointercept = trailers.apple.com
port_ssl = 443
enable_webserver_ssl = True
prevent_atv_update = True
port_dnsserver = 53
enable_plexconnect_autodetect = True
Er bricht wohl immer ab wenn die ATV auf die Mediathek zugreifen will. Als Fehlermeldung kommt nur: Trailers is unavailable. Try again later.
Ich habe mich an die Anleitung gehalten: http://miapple.me/2013/09/09/installing-plexconnect-on-windows-7-8-and-8-1-after-apple-tv-update/
Und das Certifikate wie folgt http://miapple.me/2013/11/03/plexconnect-installling-certificates-on-apple-tv-without-usb/
Wenn ich auf die Seite http://192.168.192.3:443/ aus dem Explorer besuchen will, kommt ebenfalls nur ein Ladefehler - und keine Certifikate abfrage.
Irgendeiner eine Idee? :(
Gruß
cYc
Firewall-Freigaben fuer Python?
Hatte ich auch schon vermutet, ich bin allerdings bei Unitymedia und habe die Horizon Box. Wie soll ich sagen, die Einstellungsmöglichkeiten dort sind etwas .. naja ... http://s1.directupload.net/images/131214/f9c7e3pe.jpg Ich habe auch keine Ports gesperrt
Habe genau das gleiche Szenario.
Teile es bitte mit uns, wenn du eine Lösung hast. :slight_smile:
Firewall: nicht auf dem Router, sondern in Win7...
Achsooo :) Ja diese ist komplett ausgeschaltet http://s14.directupload.net/images/131215/t2zv9aw6.jpg
edit:
Ich habe den ATV nochmal zurückgesetzt und das Profil für das Certificate neu angelegt, jetzt hat es etwas anderes ausgespuckt :unsure:
09:56:39 PlexConnect: started: 09:56:39
09:56:39 Settings: getsetting enable_plexconnect_autodetect=True
09:56:39 PlexConnect: IP_self: 192.168.192.3
09:56:39 Settings: getsetting port_webserver=80
09:56:39 Settings: getsetting hosttointercept=trailers.apple.com
09:56:39 Settings: getsetting enable_dnsserver=True
09:56:39 DNSServer: started: 09:56:39
09:56:39 Settings: getsetting port_dnsserver=53
09:56:39 Settings: getsetting ip_dnsmaster=192.168.192.1
09:56:39 Settings: getsetting prevent_atv_update=True
09:56:39 DNSServer: ***
09:56:39 DNSServer: DNSServer: Serving DNS on 192.168.192.3 port 53.
09:56:39 DNSServer: intercept: ['trailers.apple.com'] => 192.168.192.3
09:56:39 DNSServer: restrain: ['mesu.apple.com', 'appldnld.apple.com', 'appldnld.apple.com.edgesuite.net'] => 127.0.0.1
09:56:39 DNSServer: forward other to higher level DNS: 192.168.192.1
09:56:39 Settings: getsetting enable_webserver_ssl=True
09:56:39 WebServer: started: 09:56:39
09:56:39 WebServer: ***
09:56:39 WebServer: WebServer: Serving HTTP on 192.168.192.3 port 80.
09:56:39 ATVSettings: init class CATVSettings
09:56:39 ATVSettings: load settings
09:56:40 WebServer: started: 09:56:40
09:56:40 Settings: getsetting port_ssl=443
09:56:40 Settings: getsetting certfile=./assets/certificates/trailers.pem
09:56:40 WebServer: ***
09:56:40 WebServer: WebServer: Serving HTTPS on 192.168.192.3 port 443.
09:59:51 WebServer: http request header:
Host: 192.168.192.3
Connection: keep-alive
Accept-Encoding: gzip, deflate
User-Agent: iTunes-AppleTV/6.0.2 (3; 8GB; dt:12)
Accept-Language: de
Accept: */*
09:59:51 WebServer: http request path:
/trailers.der
09:59:51 Localize: aTVLanguage: de
09:59:51 WebServer: pms address:
09:59:51 WebServer: cleaned path:
/trailers.der
09:59:51 WebServer: PlexConnect options:
{'aTVScreenResolution': '720', 'aTVFirmwareVersion': '5.1', 'aTVLanguage': 'de', 'aTVAddress': '192.168.192.6'}
09:59:51 WebServer: additional arguments:
09:59:51 WebServer: serving .xml: /trailers.der
09:59:51 XMLConverter: PlexConnect Cmd:
09:59:51 PlexAPI: URL: /trailers.der
09:59:51 PlexAPI: xargs: {'X-Plex-Platform': 'iOS', 'X-Plex-Model': '3,1', 'X-Plex-Platform-Version': '5.1', 'X-Plex-Client-Platform': 'iOS', 'X-Plex-Device': 'AppleTV', 'X-Plex-Product': 'PlexConnect', 'X-Plex-Version': '0.2'}
10:00:17 DNSServer: DNS request received!
10:00:17 DNSServer: Source: ('192.168.192.6', 58763)
10:00:17 DNSServer: Domain: www.apple.com
10:00:17 DNSServer: ***forward request
10:00:17 DNSServer: -> DNS response from higher level
10:00:24 DNSServer: DNS request received!
10:00:24 DNSServer: Source: ('192.168.192.6', 60664)
10:00:24 DNSServer: Domain: p14-buy.itunes.apple.com
10:00:24 DNSServer: ***forward request
10:00:24 DNSServer: -> DNS response from higher level
10:00:28 DNSServer: DNS request received!
10:00:28 DNSServer: Source: ('192.168.192.6', 63894)
10:00:28 DNSServer: Domain: trailers.apple.com
10:00:28 DNSServer: ***intercept request
10:00:28 DNSServer: -> DNS response: 192.168.192.3
Und das spuckt er mir aus sobald ich das Profil speichere und er die trailers.der ziehen soll http://s7.directupload.net/images/131215/q8enlvmk.jpg
Ja. Ne... das ist ja auch doof.
War ein frueherer Bug in der Anleitung - das Cert File soll nicht trailers.der sondern trailers.cer heissen. Einfach umbenennen sollte klappen... dann klappt das mit dem "serve" auch!
Wow! Vielen lieben Dank Baa, das war echt noch der einzige Fehler, jetzt läuft es :))
