Dear Friends, i have installed Plexon ATV( installed Profile with configurator too). but when i start trailer on Atv, i am getting the message "No Plex Library Available". i can access my Server files from my Mac, but no access to Plex Server. ATV is running with 6.0.2. Log File Attached, thanks in Advance for a possible help....Sanju.
Use Plexify for easy setup Much easier than do it manually.
Please read the “read before posting” sticky and provide all the requested information that is needed to help troubleshoot your issue.
thank you both of you for your replies, have installed plexify, transferred certificate again, Plexconnect is up and running. but when i click on the "Trailers", comes the Message " Connecting to the Trailer" and nothing happens. i am Running OS X Mavericks and ATV 3 with 6.0.2. attaching a new Log.
Please read the "read before posting" sticky and provide all the requested information that is needed to help troubleshoot your issue.
I liked the...
more... :-D
Why should one use Plexify when having that message?
Your ATV model (2 or 3) and firmware version (found under the ATV settings > general > about > Apple TV software): ATV3,6.0.2
The DNS server set on the ATV ():192.168.1.107
The local IP address of the device that PlexConnect is installed on:192.168.1.107
The device and operating system (including version number) that PlexConnect is installed on:Mac, OSX 10.9.1
The device and operating system (including version number) that the Plex media server (PMS) is installed on: Mac, OSX 10.9.1
The Plex media server (PMS) version number you are running (do not put 'latest'): V 0.9.8.18.290-11b7fdd
The local IP address of the device that the Plex media server (PMS) is installed on: 192.168.1.107
The PlexConnect version number. If using Github source then a time and date of download (look at the creation date of the folder) and if you are using any non-standard setup e.g. Plexify or a fork.-25Nov2013 02.17AM
Log ———————————————————————————-
11:44:05 PlexConnect: started: 11:44:05
11:44:05 PlexConnect: Version: 0.3.1+
11:44:05 PlexConnect: Python: 2.7.5 (default, Sep 12 2013, 21:33:34)
[GCC 4.2.1 Compatible Apple LLVM 5.0 (clang-500.0.68)]
11:44:05 PlexConnect: Host OS: darwin
11:44:05 PlexConnect: IP_self: 192.168.1.107
11:44:05 DNSServer: started: 11:44:05
11:44:05 DNSServer: ***
11:44:05 DNSServer: DNSServer: Serving DNS on 192.168.1.107 port 53.
11:44:05 WebServer: started: 11:44:05
11:44:05 WebServer: ***
11:44:05 WebServer: WebServer: Serving HTTP on 192.168.1.107 port 80.
11:44:06 WebServer: started: 11:44:06
11:44:06 WebServer: ***
11:44:06 WebServer: WebServer: Serving HTTPS on 192.168.1.107 port 443.
11:49:20 ATVSettings: add section DY3KK34KFF54
11:49:20 PlexAPI: ***
11:49:20 PlexAPI: looking up Plex Media Server
11:49:21 PlexAPI: GDM: No servers discovered
11:49:21 PlexAPI: Servers (local+MyPlex): 0
11:50:35 PlexAPI: MyPlex Sign In successfull
11:50:35 PlexAPI: ***
11:50:35 PlexAPI: looking up Plex Media Server
11:50:36 PlexAPI: GDM: No servers discovered
11:50:37 PlexAPI: Servers (local+MyPlex): 0
11:53:39 PlexAPI: ***
11:53:39 PlexAPI: looking up Plex Media Server
11:53:40 PlexAPI: GDM: No servers discovered
11:53:42 PlexAPI: Servers (local+MyPlex): 0
Settings.cfg—————————————————————————
[PlexConnect]
port_pms = 32400
port_webserver = 80
ip_plexconnect = 0.0.0.0
certfile = ./assets/certificates/trailers.pem
ip_dnsmaster = 8.8.8.8
loglevel = Normal
enable_dnsserver = True
logpath = .
ip_pms = 192.168.1.107
enable_plexgdm = True
hosttointercept = trailers.apple.com
port_ssl = 443
enable_webserver_ssl = True
prevent_atv_update = True
port_dnsserver = 53
enable_plexconnect_autodetect = True
Thanking you All, Sanju.
Is plexgdm enabled on your PMS?
What happens if you turn enable_plexgdm = False and the. Enter your PMS IP address in ip_pms ?
thanks for the reply,
i have turned the enable_plexgdm = false, nothing happens. i can access the files from my Mac (Itunes) through Channels on Trailers Menu. but the Library is still empty.......!! Sanju.
Silly question: Your PMS is nicely set up with library and section?
thanks for ur reply, but didn't understand your point. i meant, when i click on the "trailers" in ATV Menu, there comes 4 Menus, therefrom i can access only my files from laptop. thanks again, Sanju.
Yeah. Well. No.
You can not access all your files form your laptop - only the ones PlexMediaServer is setup to show/serve.
On your Mac, run PMS, go to MediaManager and add sections for Movies, Shows, Photos... point them to you local storage and Plex will make it all nice and shiny.
aaahhh, ok, got it.i mean naturally the files which are added to PMS library. my prob. is couldn't access any movies from Plex Server. thanks again, Sanju.
