Server Version#: 1.18.9.2571
Player Version#: 2.53.0.1063-4c40422c
I am getting audio dropouts at random times when playing movies. I watched a bit of the movie with my receiver on screen info display on and it appears like the audio signal is actually cutting out for a second at random intervals. The last movie I was watching when the issue happened had a TrueHD audio track. (I’m not sure yet if it happens with other audio codecs like DTS-HD MA)
After scouring the forums I thought I would try changing from bitstreaming TrueHD to having Plex decode and send PCM. Initial results seem to indicate that the issue doesn’t happen when Plex decodes and sends PCM.
I looked in the logs of both PMS and PMP but saw nothing.
Doesn’t anyone know why this issue occurs when bitsreaming TrueHD and how to fix it?
