Audio Out of sync
Server Version#:1.9.0.1203-00f2b4d9
Player Version#: 8.0.1.17410
I’ve only noticed this issue on Android TV. While playing 1 particular show (not another), the audio goes out of sync where there is a commercial gap.
I cannot reproduce the issue with VLC, only with Plex. The audio will be off by roughly the same amount of time as the black commercial gap. Only way I found how to resync audio is skip forward then jump back (or vice versa).
I suspect it’s the way it was ripped, because it only happens on this show, and every episode.
This happens when using direct play and transcoding.
This is the media info from one episode.:
Media
Duration 42:21
Bitrate 4009 kbps
Width 1280
Height 720
Aspect Ratio 1.78
Video Resolution 720p
Container MKV
Video Frame Rate 24p
Video Profile high
Part
Duration 42:21
File Blue Mountain State S03E12.mkv
Size 1.19 GB
Container MKV
Indexes sd
Video Profile high
Codec H264
Bitrate 3625 kbps
Language English
Bit Depth 8
Chroma Location left
Chroma Subsampling 4:2:0
Coded Height 720
Coded Width 1280
Frame Rate 23.976 fps
Height 720
Level 4.1
Profile high
Ref Frames 5
Scan Type progressive
Width 1280
Display Title 720p (H.264)
Codec AC3
Channels 6
Bitrate 384 kbps
Audio Channel Layout 5.1(side)
Sampling Rate 48000 Hz
Display Title Unknown (AC3 5.1)
