If you select an album to play in the web browser version - it does not move to the next track if the tab has lost focus or is minimised - as soon as you give back the focus to the tab it starts playing again - anyone else had this problem?
Try a different web browser. It might be a ‘power saving’ feature of the used web browser which interferes here.
Or switch to plexamp.com
Also check for any extensions that you may have that could affect the playback. Using the ‘Disable HTML5 Autoplay’ extension under Chrome would prevent the playing of the next track until I added a rule to block nothing on my plex server.
