Plex shield tv pro problem with sound codec dts master hd and neuralx upmixer
Hi, im from Germany.
I have problem when i watch oblivion 4k and the german dts high reselution audio. When my avr add neural x to upscale the audio to my height speakers i get sound problems. The sound is like scratches or like the sound is to big for the speaker.
When i hear the English version is it ok. When i deactivated neural x in avr also.
This problem is only in the oblivion movi with plex and my nvidia shield pro.
When i play the same file over a pc i have this problem not and when i play my orginal over a bluray player is also fine.
Users had pointed out your post wasn’t really linked to the thread you had posted it in. Therefore I’m moving it into its own thread.
On what Plex client/app are you experiencing this issue (version and platform)?
Nvidia shield pro tv android version 8.25.1.28703 plex server is on synology nas.
Can you provide some details about that German audio track?
e.g. from > Get InfoView XML, looking for that particular Stream element representing that audio track
Original Technical Details
Dateien
  • /volume1/video/Oblivion.mkv
Medien
  • Duration 2:04:37
  • Bitrate 61547 kbps
  • Width 3840
  • Height 2160
  • Aspect Ratio 1.78
  • Video Resolution 4K
  • Container MKV
  • Video Frame Rate 24p
  • Audio Profile hra
  • Video Profile main 10
Teil
  • Duration 2:04:37
  • File Oblivion.mkv
  • Size 53.64 GB
  • Audio Profile hra
  • Container MKV
  • Codec HEVC
  • Bitrate 55025 kbps
  • Bit Depth 10
  • Chroma Subsampling 4:2:0
  • Coded Height 2160
  • Coded Width 3840
  • Color Primaries bt2020
  • Color Range tv
  • Color Space bt2020nc
  • Color Trc smpte2084
  • Frame Rate 23.976 fps
  • Height 2160
  • Level 5.1
  • Profil main 10
  • Ref Frames 1
  • Width 3840
  • Display Title 4K (HEVC Main 10 HDR)
  • Extended Display Title 4K (HEVC Main 10 HDR)
  • Codec TRUEHD
  • Kanäle 8
  • Bitrate 4309 kbps
  • Sprache Englisch
  • Language Tag en
  • Audio Channel Layout 7.1
  • Bit Depth 24
  • Sampling Rate 48000 Hz
  • Display Title Englisch (TRUEHD 7.1)
  • Extended Display Title Englisch (TRUEHD 7.1)
  • Codec DCA
  • Kanäle 8
  • Bitrate 2046 kbps
  • Sprache Deutsch
  • Language Tag de
  • Bit Depth 24
  • Profil hra
  • Display Title Deutsch (DTS-HD HRA 7.1)
  • Extended Display Title Deutsch (DTS-HD HRA 7.1)
  • Codec PGS
  • Bitrate 20 kbps
  • Sprache Englisch
  • Language Tag en
  • Display Title Englisch (PGS)
  • Extended Display Title Englisch (PGS)
  • Codec PGS
  • Bitrate 21 kbps
  • Sprache Deutsch
  • Language Tag de
  • Display Title Deutsch (PGS)
  • Extended Display Title Deutsch (PGS)
  • Codec PGS
  • Bitrate 63 kbps
  • Sprache Englisch
  • Language Tag en
  • Codec PGS
  • Bitrate 64 kbps
  • Sprache Deutsch
  • Language Tag de
  • Codec PGS
  • Sprache Deutsch
  • Language Tag de
[Mod-Edit: transferred the audio details into a table for better readability / comparison]
Parameter English Audio Stream German Audio Stream
Codec TRUEHD DCA
Channels 8 8
Bitrate 4309 kbps 2046 kbps
Language Englisch Deutsch
Language Tag en de
Audio Channel Layout 7.1 7.1
Bit Depth 24 24
Sampling Rate 48000 Hz 48000 Hz
Display Title Englisch (TRUEHD 7.1) Deutsch (DTS-HD HRA 7.1)
Extended Display Title Englisch (TRUEHD 7.1) Deutsch (DTS-HD HRA 7.1)
Does your A/V receiver decode the file properly if you feed it through some other means (e.g. if it can read the file from a DLNA device or file share)?
If configured accordingly, your Android TV Plex should pass-through the audio stream as-is. So this could actually be an issue with the audio stream itself.
When i use this video with plex it works withel the english language with out problems i can also add neuralx to the sound.
When i use the German language and i dont add neuralx i have no sound problems over plex. It just start when i add neuralx.
When i play the exact video over my pc directly i can use German with neuralx and when i put the orginal video in my Blurayplayer also no sound problems with neuralx.
When i use other videos on plex i can use always neuralx. Is only oblivion that make this problem.
My avr is marantz 6015 5.1.4 my setup
Does the Plex “Now Playing” Dashboard show that the audio is Direct Play or Direct Stream? Or something else?
What format is the Shield outputting?
During playback, does the receiver show that it is receiving the DCA/DTS 7.1 stream?
When i make the english one that run without noises it look so
The german one run so without noises
When i use this so.
When i watch monster hunter uhd is the same problems in the German language when i add neuralx to the dts high resolution audio.
I have test kodi on the same device and with kodi the sound is perfectly.
Please fix this problem with dts masterhd and neuralx.
From the Shield Experience 9 release notes
  • Adds support for DTS-HD HRA audio streams
However, the rollout of Shield Experience 9 has not been exactly smooth. Read the other posts on the Shield forum. Also the Plex thread linked below. You may want to wait for things to stabilize before updating your Shield, especially if you also use it as a Plex Media Server.
My problem was befor the upgrade. Since upgrade i didn’t used plex.
My plex server is on synology s220+ dsm 7 wothe last update, i think 2 or 3 days old.
I just tested again. Oblivion run now without sound issues.
I use android beta versions plex. And version 9.0.0 is also installed.
