Audio track naming
Server Version#: 1.30.0.6486
Happy new year to you all, thanks for the great work over the past few years. I have very few gripes, infact only 2 and 1 is already being resolved, thank you for that.
The second grip is to do with Audio tracks for movies and TV series, I sometimes have multiple audio track for different outputs (5.1 suround, stereo, and passthrough), all of these will be named to make it easier for me to identify the correct audio track for the current circumstance, but when using a player on plex web or even android, the track names are stipped out and its a case of trying to remember the track or guessing. Can this be resolved so that audio tracks, and subtitle tracks retain their names?
This is AFAIK only possible if you use the MKV container for your videos.
grafik
okay thank you :slight_smile:
