Server Version#: 1.13.0.5023
When the transcode directory is changed from the default and the media server has to transcode E-AC3 audio, it fails throwing the error " Conversion failed. A required codec could not be found or failed to install."
When I change the transcode temporary directory back to the default, it works without issue. Please correct this. Thanks!
