Server Version#:1.16.2.1297
Player Version#: 3.108.2
Hello,
I’M unable to transcode any video with EAC3 sound.
Each time, the video player starts, but no video is display. I only see the waiting sign.
While the problem occurs, I can see in the logs errors like:
Jul 22, 2019 22:53:51.001 [0x7fef84ff9700] ERROR - [Transcoder] [eac3_eae @ 0xc2ab80] EAE timeout! EAE not running, or wrong folder? Could not read '/tmp/pms-88a9b466-ee4f-40e0-a2fe-0237a48fda02/EasyAudioEncoder/Convert to WAV (to 8ch or less)/21zqxfwxmdm3n2wcu61dksej_16986-0-4.wav'
Jul 22, 2019 22:53:51.002 [0x7fef627fc700] ERROR - [Transcoder] [eac3_eae @ 0xc2ab80] error reading output
Jul 22, 2019 22:53:51.002 [0x7fef627fc700] ERROR - [Transcoder] Error while decoding stream #0:1: Input/output error
If I check the “/tmp/pms-88a9b466-ee4f-40e0-a2fe-0237a48fda02/EasyAudioEncoder/Convert to WAV (to 8ch or less)/” directory I can see ec3 files, but no WAV.
Thanks for your reply.
No, it’s on the main NVMe driver on which the system is installed.
I run it on Ubuntu 18.04 (headless) natively, but I have the same issue on 2 different docker containers. Each time, I use a copy of the same library.
I wondering if something can be wrong in my settings.
Sorry, it’s not cristal clear.
I have this issue since a while.
I’m used to run PMS on docker, but recently I got a P4000.
So, I migrated on a native installation and face exactly the same issue.
I no longer want to use docker.
Seeing the same issue on the native installation, I suspect that the problem either comes from my settings (copied from docker to native) or my system.
I don’t know exactly when it stopped working.
I tried to downgrade to 1.15.8.1198, but it didn’t helped.
My Library folder is pretty old. Copied from an install to another. So I tried to create new settings, and it worked.
Now I’m looking how to get back my database without copying settings.
End of the story.
Maybe somebody is in the same situation, so here are the steps to solve the issue.
The problem came from my Preferences.xml file. My oldest previous version is 1.12.0.4829-6de959918.
I basically stripped out the file to keep only server identity.
