Auto sign in not available to all users?
Server Version#: docker latest
Player Version#: various
I have family members added to my Plex home.
When logged in as them, In settings. The auto sign in option is not available.
How do I enable this option for all my remote users?
These aren’t managed users. These are family members own independent individual accounts.
If I switch user to one of their accounts when I am at home on the local network and I go into settings. The auto sign in is missing.
If I change back to my user/admin. Then it is there.
Only the admin for Plex Home is allowed to set that. Once you do, the setting applies to every other account.
I thought that was only the case for managed users where the admin had to set the sign in automatically option. I am pretty sure in the past it worked that if you had your own Plex account (as in the case for the OP), you would be able to set that option. It was only with managed users that the admin needed to set that option for it to apply for them (and it had no bearing on the users that had an actual Plex account).
Edit: Also, if that is the case the support article (at least for the Android TV settings) does not make it clear that is how it works. Furthermore, the support article doesn’t make it clear that needs to be done for managed users (at a minimum), though I can’t remember if I had found that information in the forum or on one of the support pages when I ran into that issue.
-Shark2k
AFAIK, it’s always been this way. I’ll see about adding the note to the support article.
Where do I set it then for non managed users?
The setting is not for the user. It is a device setting. That setting is to automatically sign in as the last user bypassing any PIN restrictions. So if the Uncle Bob user was last signed in, the next time you turn on the app, it will use Uncle Bob’s account again without asking for his PIN.
Sorry @anon18523487, I just found something from BigWheel that contradicts what you are saying.
See this post here: Auto logon when I open the app
-Shark2k
What apps specifically are you/they using?
It is a setting per device in that if it is on for one person it is on for everyone. The setting should be there for all users in home except managed. Are on my Androids and the web browser app. Not aware of any changes there.
On PS4 and Samsung 2018 TV.
If I am on my account (the owner, main user, one with the crown).
On settings, I have the option for automatically sign in.
If I switch users to another account within my home.
On settings the option to automatically sign in is missing.
OK. I’m going to make a report for that app.
I believe it’s the same on the LG
Yeah it will be the same on all the Smart TV and Game Console apps that all share the same UI.
Thanks for jumping into the thread @BigWheel and helping out with this.
@anon18523487, just want to make sure I didn’t come across as a jerk in my reply, as that was not my intention. I was just pretty sure the option was supposed to be visible to all but managed users in a home, as BigWheel confirmed in his one reply in this thread and the thread I linked.
-Shark2k
No problem. I hadn’t seen the option available for other users before so I thought that was intended.
Is there any update on this?
Appreciate it’s only been a week but is it in there to be fixed?
Any news on this??
