Server Version#: 1.23.4.4712
Player Version#: 8.18.2.25850 ( Android mobile)
Phone: Oneplus 5t.
System config: Ryzen 5 3600, Nvidia quadro p400, 16GB
Result(Success): Video keep playing and quality is adjusted according to speed
Result(Failure): Video get stuck in forever loop… server keeps giving log [TranscodeOutputStream] Delaying subtitle output to wait for video stream to catch up
Issue:
- Seems to be happening only on android clients with SRT subtitles ( Tested mac, web, windows client these seem to be working fine)
- Happening on multiple servers ( checked with friends server also )
Scenarios(can be reproduced with these steps):
- Subtitle disabled/off for file before playing
Result: Success
a) Subtitle turned on after video started playing
Result: Failure - Subtitle enabled/on for file before playing
Result: Failure
a) Subtitle turned off after video started playing
Result: Success
Steps for generating these logs:
START network log
- select any movie
- Disable logs before playing the video
- Play the Video for 2-4second => it will play normally with automatically adjusting the quality
- Enable/add subtitle => ( video will keep loading) server will be stuck in some kind of loop
END network log
get logs from server and client.
Repeat the same while verbose enabled.
- Android client logs
- Server logs
- Server logs while verbose enabled.
Plex Media Server Logs_2021-07-04_19-43-19(verbose).zip (3.4 MB)
Plex Media Server Logs_2021-07-04_19-40-50.zip (3.4 MB)
plex-android-debugging.txt (4.7 MB)
