When an episode finish, it simply show the thumbnail of the current episode with a replay sign on it. It used to simply go to next episode after 5 sec, but now the screen is simply blank (with current episode thumbnail).
It used to work without any issue, I don’t know when it broke but it has been broken for a long while now. I tried the 8.19 version and it worked there. But when I tried 8.30 it was broken. And after that I’ve tried every major 9.x release and it seems to be broken.
I’m currently on Plex server: Version Latest Plex version on Android.
Server Version#: 1.28.2.6151
Player Version#: Tried official latest release on Amazon App store, and also currently 9.9.0.35492 BETA
Here are the logs, I turned the network logs on, and played an episode and went to last 10 secs and let it finish, and after it finished it simply ended up on the end screen where it just showed the same episode thumbnail without autoplaying the next episode.
App version: 9.9.0.35492 (848865856) - ERROR
[LOG] Plex-Up next Episode Error.txt (343.8 KB)
And here’s the same scenario with App version: 8.19.2.26351 (825650936) which works
[LOG WORKS] Plex-Up next Episode Error.txt (324.4 KB)
I hope it helps you finding the issue.
