AV sync issue on Live TV (1080i/576i)
Live TV stream now goes out of sync regularly if the signal drops for a second or we skip ads. Skipping back 10 seconds puts it back into sync. Leaving it playing doesn’t bring it back into sync automatically.
Signal is excellent and no issues with audio sync via HDHomeRun App when skipping back.
I was under the impression all players these days use time codes or similar to check the stream and re-sync automatically if this occurs?
Same issue on 2019 Shield and 2017 Shield, one playing to a Sony TV other to Projector via Yamaha receiver.
NVIDIA Shield Server: 1.22.3.4523 (smb)
Android TV Plex App: 8.17.1.25326
DVR: HDHomeRun CONNECT QUATRO FW 20210224
DVB-T Transmission details:
– Resolutions: 576i, 720p, 1080i
– Aspect Ratio (Normally wide screen 16:9 but could be 4:3)
– Video Encoding – MPEG-2 or MPEG-4 (H.264) for video
– Audio Encoding – MPEG-1, AAC or AC-3 (both 2.0 and 5.1 DD) for audio.
– Digital bit-rate – for each program and total to be transmitted
More info here: https://www.freetv.com.au/wp-content/uploads/2019/08/OP-71-Recommended-DVB-T-Transmitter-Modulator-Settings-Issue-1-December-2014.pdf
thank you in advance
