Background Art
I have multiple libraries (animated movies, kids movies, movies, tv shows, kids tv shows) the background art from animated used to only show the artwork from the movies in the animated library. It now shows artwork for any movie. all others do the same, except tv shows only has artwork for the correct tv show library. Any ideas how to fix this?
What version of OpenPHT and What skin are you using?
Openpht 1.8.0 and it doesn’t matter which skin. It is the same on all skins
I figured it out… I had unchecked “include in dashboard” in Plex library settings.
