Background play stops at end of episode
I like to use the background play in combination with the sleep timer at night.
Issue is, if I’m using background play, the playback just stops at the end of an episode, it doesn’t start playing the next one Even if it hasn’t reached the end of the sleep timer.
Example: I turn on my Futurama playlist, set the sleep timer for 1 hour, turn off the screen, initiate background play, and 20 minutes later, at the end of the episode, it stops playing altogether.
Any way around this or is this a feature request?
