Server Version#:
I have Plex running on a Raspberry Pi running Raspbian. The problem is that the OS got corrupted and I can’t make any network connections. I have got to the stage where I have exhausted troubleshooting, and will just start a fresh build.
Before I do, I have hooked up a monitor and keyboard to try and back-up the database. I had spent quite a bit of time ‘matching’ items, and don’t want to have to go through that again.
In this article I found that the database location for Debian (which Raspbian is based on) is located in:
/var/lib/plexmediaserver/Library/Application Support/Plex Media Server/
I have tried copying the whole of this folder to an external HDD, but keep getting errors that some files could not be copied. I have run the command
sudo service plexmediaserver stop
which has not resolved the issue.
Does anyone have any advice?
