Folks I have a synology that runs my Plex, and I love it. My synology has had issues in the past requiring a complete reinstall of plex. This of course wiped out all the information I spent years adding to make the entries in the plex the best they can be. Looking at how to backup up the library information - shows are covered - is what I need to tackle next to make sure I don’t lose all my work, again.
BUT this isn’t listed in the support article section, submitting this post did not show a suggestion any more recent that 2014. I find ti hard to believe I am the only one wanting to do this. Perhaps I am missing it or my google searches are flawed… regardless can I get the process to backup and restore on a synology? Thank you
ChuckPA thanks for the suggestion, unfortunately, the File Station does not show the Plex directory. I can’t find a nerd knob to change the setting of file station to allow it to be displayed.
Thank you ChuckPA we are getting closer. Your instructions allows me to ‘see’ the Plex directory in File Station. I set myself with RW privileges. Now that I see the directory I went back to your instructions and tried to compress/archive it… that option is not an active selection, its all grayed out. I will add a picture to this reply.
