I have a TV Shows Library that if I view the library I get a badge showing the number of series I have not watched per show. eg: Shrinking is showing 8 episodes for Season 3. I have completely watched seasons 1 & 2. So correct so far.
I go home and look at Recently Added and Shrinking is not showing any badge at all. Why?
TIA
EDIT: Also if I open Shrinking from Recently Added it goes to the last episode and not the first.
The Recently Added hub doesn’t necessarily list a show.
Depending on how you added those episodes, it’ll list individual episodes or group them by season / show (iirc, the grouping will consider items added within a period of 20 hours):
If you only added 1 episode within that period, recently added will list the episode
If you added multiple episodes of the same season or an entire season, recently added will list the season
If you added multiple episodes spanning seasons, multiple seasons or the entire show, recently added will list the show
Depending on the type of the record, you should see the badge indicating the number of unwatched episodes of the show or season. If there’s only a single episode, no badge will be displayed.
